![]() Join Date: Jul 2002
Post your SAFC-II Specs.
I need some help tuning my car. I have a KA-T, T3/T4, SR Injectors, Walbro 255, HKS SSQV, and a SAFC-II. I would like to get the Lo-Thrtl, NE Points (so I can have the right correction for the BOV), and Dec. Air. PLEASE HELP!
![]() Join Date: Aug 2003
They are going to be different for every car, you cannot simply copy one persons settings and expect to make the same power, or even have your engine live. You need a wideband, or a dyno with a wideband to do REAL tuning. What works for me doesn't work for other people and vice versa. If your just trying to get your car to the dyno, use -20 across the board on Lo throttle and DO NOT BOOST on your way there. This is not something to take a shortcut on.
95 240sx Got KA-t? |
Shit man, his question is legit, you can mod them a little bit if someone has a similar setup, I'm running a SR and am getting it worked on right now otherwise I'd help you out.
