Stock size (SR20) aftermarket Throttle body options?
So, I am currently in search of an aftermarket TB that has the same size as the stock SR20 (66m??) throttle body
Most if not all the Ebay/knock off Amazon ones seems to leak with no real remedy. Also not interested in throttle body screws in my engine. Just wanted a much simpler throttle body that doesn't have the coolant lines or the wax thermostat, etc. Whats out there currently that's not exorbitantly expensive?? Looking for a straight bolt on to the SR20 flange P.S I do not need opinions on why blah blah blah. I have my reasons, so just feed me the info as I am having a hard time locating anything outside of Hypertune. |
My SR20VET |
![]() Join Date: Jul 2005
What, your motor doesn't like eating the screws? Whats wrong with it ;D
everyone knows the sr demands a healthy diet of TB screws Why not trying taking apart an OEM TB and 'fixing it' the way you want, Or you can always install a ball-valve (from home depot) on the IACV line to limit the max airflow of the IACV (helps hold down the idle when the TB is cold) |
#6 | |
The car is still in Florida. When we moved, I didn’t have anywhere to keep it so it stayed with my parents in their garage. Now that I have 5 garage spaces, I just need some spare time and funds to go get it.
My SR20VET |
