Old 11-14-2008, 09:04 AM   #1
angeldunk707
angeldunk707's Avatar
angeldunk707 is an unknown quantity at this point
yet another LSD question
ok i have a 89 s13 coupe and i just did a sr swap and im gonna need lsd. im looking into gettin a z32 just to get me by until i can get the tomei 2-way. is there anything i'll need to do the z32 lsd or will it bolt right up to my open diff?
if anyone has suggestions please list them thank you
angeldunk707 is offline   Reply With Quote
Old 11-14-2008, 09:54 AM   #2
ZipTied
ZipTied's Avatar
ZipTied is an unknown quantity at this point
If your just looking for a temp fix just weld your open diff. No point in buying one if your gonna use it for a bit then det something else.
ZipTied is offline   Reply With Quote
Old 11-14-2008, 12:20 PM   #3
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
open the LSD up and shim it, check out the "shimming LSD" thread
you wont even need to buy another lsd.
Chrischeezer is offline   Reply With Quote
Old 11-15-2008, 02:09 PM   #4
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
I too would just weld yours till you got the money for the tomie. I dont like the vlsd at all. I do have the tomie 2 way from eat motorsports and it is amazing! Kinda loud though.
4x4le is offline   Reply With Quote
Old 11-15-2008, 02:19 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Don't bother trying to swap a vlsd in your open diff housing. It'll get pricey. You don't just bolt it into the housing, you have to set-up the bearing pre-load and gear pattern. You would be better off finding a vlsd that is already in the housing and just swapping the pumpkin.
racepar1 is offline   Reply With Quote
Old 11-15-2008, 02:25 PM   #6
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
well, were i live i can get a vlsd rear end for 75$. So If you can i would say go to a junkyard and pick up a vlsd, maybe a small shim and good oil and your set.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 11-16-2008, 03:30 PM   #7
kotea
kotea is an unknown quantity at this point
weld what you have for temporary.
kotea is offline   Reply With Quote
