Garage Life: Roll Cage Summer Special!!!
GARAGE LIFE IS HAVING A ROLL CAGE SUMMER SPECIAL!!! What better way to make sure you're protected at the track than to have a roll cage in your track beast? Whether you want a basic 4 point cage to a full on Formula D cage, we can do that for you! With your choice of 1.5 0.95 DOM or 1.75 0.95 DOM. (For any other type of material, give us a call and we will check on that for you.) The cage is tailored to the driver so you can be sure that the cage is made to fit YOU! PRICING: $600- A basic 4 point cage with lateral and harness bars with 2 back stays. This can be made into a full cage later on. starting at $1500- A basic 6 point cage that is Formula D legal and will pass the Redline Time Attack standards. This includes 2 rear back stays, the main hoop, the lateral and harness bars, forward halo, the A pillar bars and X door bars. $200 EXTENDED FORWARD BARS-According to the new 2013 Formula D rules, the forward bars need to be extended from the A pillar bars to the firewall. $200/pair OR $100 each - GUSSETS!! NOTE:The windshield will need to be removed for 6 point cages. We can remove and replace the front windshield for $150-$250 depending on the make and model of the car. $200- Nascar door bars. For all the NASCAR fans out there Additional points available if wanted! You can contact us through email at [email protected] Or you can call us at 626-455-0415 GARAGE LIFE 11128 Rush St. South El Monte, CA 91733 These cages are for off road use ONLY. |
