Prev Previous Post   Next Post Next
Old 09-06-2012, 02:19 PM   #1
koukidriver
koukidriver's Avatar
koukidriver is an unknown quantity at this point
Send a message via Yahoo to koukidriver
1995 S14 KA-T for sale Fully built
This has been my pride and joy for years always garaged kept and driven only in the summer months I have spent well over 15k into this car. I rarely get to enjoy it and it time to let her go to a new home.
Wiseco coated, forged pistons (9:1)
Eagle forged H-beam rods
block tanked, cylinders bored 1.0 mm over (90mm bore), fully component balanced
NEW cylinder head w/Wiseco MLS headgasket
PDM Racing stage 2 Tri-flow cams, 272/278 advertised duration
All Supertech valvetrain, SS nitrated, 1mm oversized valves, dual SS springs, Ti retainers and seats
Mild porting and de-shrouding done to the head with 3 angle valve job
Toga high volume oil pump, and new lower front cover, toga high performance bearings
740cc DW injectors
Walbro 255lph fuel pump
Fuel Pressure Regualtor with a in-line gauge
Z32 Maf with adapter plate
Apexi air filer
JW Ecu
ISIS V2 Tubular Exhaust Turbo Manifold
Garret Gt3071r (A/R .50) (.86) exhaust Internally Gated (14psi)
Oil feed and return SS lines with oil restrictor
Coolant feed and return (AN)
CX intercooler with HKS SSbov
Koyo Aluminum Radiator
Altima fans and DIF fan controller
Nismo thermostat
Silcone coolant hoses
JGS motor and trans mounts
Excessive lower motor mount brackets
MR. Gasket copper exhaust gasket
Oil,Coolant and Boost Gauges
Megan 3-inch downpipe
Catco 3-inch Cat
Apexi Megaphone Exhaust
Fully built Auto trans by IPT
Suspension
Rear Spc UCA
Front Tein tension rods
J30 Diff
Also the car has AC
Alarm:
Viper 5902 alarm system
Viper Smart Start - has about more than 6 months left on subscription - can track car using iPhone, Android, or Blackberry
Window Automation System 530T for Viper System - when car is locked windows roll up automatically
Digital Tilt Motion Sensor 507M for Viper System - calibrates when car is turned off and if car is raised when alarm is on, it will go off
Backup Battery Siren 515R for Viper System
Backup Battery System 520T for Viper System
Audio Glass Break Sensor 506T for Viper System
Audio:
Panasonic 200w Motorized AM/FM/MEA Model# CQC8803U
Hybrid Imagine 6.5" Convertible 2-way Coaxial/Component System audio speakers
Front and rear
( BTW the word convertible means that you can separate the tweeter from the 6.5 mid-bass speaker which I did in the front and installed the tweeter in the stock A-Pillar location.)
Signal Auto Carbon Fiber Center Taillight Cover (Pretty Rare)
Parts not installed:
Brembo Evo 8 calipers with adapter plates (fronts only)
Megan racing lower control arms for the rear (BNIB)
Asking 5,500 Firm no trades.
koukidriver is offline
