So I get in my car today (91 KA24DE) and go to start it, and NOTHING. So i turn on my dome light and nothing so I assume dead battery. Throw it on the charger let it charge 20 mins and says charged. Go to start and still nothing. So i guess bad battery or bad charger and go pull my optima battery out of the mustang. Get in and turn the key to aux and everything turns on but when i try to start NOTHING and then none of the aux work again. WTF????
![]() And, if i disconnect the battery for few seconds then hook it back up aux works until i try to start it again. I HAVE NO CLUE what this could be. ANY IDEAS WOULD HELP. THANK YOU |
You arent tightening the connecters properly...
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
nope.. you might think you are connecting it properly but i would suggest to try and make them fit tighter..
and yes im talking about the connectors on the battery...
Well i feel really stupid, i replaced the connector for the positive cable and it started right up. I looked at the old one and it was cracked so that was apparently the problem. Thank YOU!!
