s14 owners I have an easy question! Need your help!
Simple story:
I need someone with cruise control on their s14 to go look at it and tell me the wire colors on the (harness plug) that connect to the cruise control pumps (pigtail). My pump has a 4 wire pigtail on it. colors being Blue- Green- White - Black- If you could tell me what colors on the harness plug go to each (on my pigtail), it would be greatly appreciated!. The pump is located on the passenger side firewall behind the wheel well. details: I have a 1996 zenki with an rb25det swap and am trying to get my cruise control back up and going. Wiring specialties did not wire my harness back up with the plug for whatever reason so i am going to have to wire it directly into my m62 plug myself.
My SR20VET |
that post doesnt help me in this situation. I dont have the connector for the harness side of the cruise control box since i sent my harness to yuri. which is why i need someone to fill in these colors for me... thanks though...
Ah I was thinking you didn't have the wires in the m6x plug.
My SR20VET |
not a problem at all i have the fsm so if i could just get someone to tell me what the wires colors are to the ones on my pump i should be golden. Thanks again though!
Alright, I did alittle research for you.
This is was I have from the FSM. *Edit- Correct wiring/terminations are two posts below...*
My SR20VET Last edited by jr_ss; 12-19-2012 at 06:22 PM.. |
this always confuses me but for future reference, when it shows a connector in the fsm, is it showing it from the wire side of the connector or from the plug side (if that makes any sense)
and thank you for the help!!!!!!
#8 | |
Rechecking things, the white wire is your power wire to the unit. With that said, looking at the pump connector from the backside, from left to right it goes 2, 1 on the top row and 4, 3 on the bottom row. #1 is the white wire, which connects to the blue/white wire. #2 is the blue wire, which connects to the blue wire. #3 is the black wire, which connects to the green/yellow wire. #4 is the green wire, which connects to the blue/black wire.
My SR20VET |
been working on this for a few days now. finally got it wired up and took it out for a test... FAIL! keep you posted on the outcome about to rip my hair out!
EDIT SHIT I JUST NOTICED YOUR POSTS ARE DIRRERENT! I HAVE BEEN WORKING OFF THE FIRST COLORS AND YOUR SECOND IS DIFFERENT>>>GONNA TRY THE LATEST POST.
Cruise control 'd rb25det complete. JR_SS thank you for your time and help! you may want to edit your first post on the plug terminals. the second is the correct one! THNKS AGAIN
No problem, glad you got it sorted out. I edited my post above as well, thanks.
My SR20VET |
