s13 smells like gas and thick white smoke
i just inherited my uncles s13 red top sr20. the car sat for maybe a month, but the first time i started the car it poured out thick white smoke that smelled like gas. even the dipstick smells of gas and the car continues to do this. i described this to some one and they told me to take the car to get tuned or that it could be a fuel injector thats stuck open. ( the smoke and gas smells coming from the exhaust) somebody help me........
![]() Last edited by dave87rx7; 03-12-2011 at 07:35 AM.. Reason: spelling |
Look at your oil if there is any white residue / anti freeze in there its your head gasket, depending on where you live you might also have the wrong weight oil for the temperature outside.
![]() Join Date: Dec 2008
Are you sure your not confusing the fuel with oil in the coolant? It sounds like a bad headgasket to me. Go to autozone and buy some alumaseal and throw it in the radiator and see if the smoking stops.
On my rx7 I had a blown coolant seal and there was white smoke like there was no tomorrow. Put some alumaseal in it and 20 min of idiling, what ya know, no more smoke. Shits lke $3. Its worth a try.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
#8 | |
i pulled all the plugs today to find them socked in gas so with the plugs out and the fuel pump switch off i cracked the motor to pump the gas out. it was coming out pretty good then slowed down a bit but one cylinder was pushing it out pretty good ????
so all of the plugs were soaked with fuel? and all of the cylinders spit out the same amount of fuel when you cranked it with the plugs out and fuel pump disabled? sounds like all of the injectors are dumping a lot of fuel. as stated above, check for leaking o rings, MAF, coolant temp sensor, vacuum leaks, fpr. also change the oil before you start the engine again. all that fuel in the oil will ruin the bearings, crank, and cam journals. good luck.
#12 | |
bad engine bearings will make the engine knock or rattle. if you did not drive the car, i doubt you damaged anything. check number three`s injector o ring. i would replace all of them though. make sure you lubricate the new ones before you slip the injectors back in the fuel rail.
