Old 04-17-2019, 10:35 AM   #1
Lock-kime
Lock-kime is an unknown quantity at this point
Ignition wiring help
Just picked up a 93 s13. The previous owner never got it running. Somebody at some point I found, replaced the ignition switch and jacked up a bunch of wiring. I finally got some stuff working but no power from the ignition to the fuel pump fuse or relay. The new plug coming off of the ignition switch has different color wires than the plug it plugs into right under the driver side dash. Someone messed that plug up pretty bad. Anyone know what color wire controls what at that plug? White seems to be constant 12v.
Or if you could just take a picture of the plug connection under the driver side dash coming from the ignition I can see where what color wires are landed in the plug.
Lock-kime is offline   Reply With Quote
Old 04-23-2019, 04:19 PM   #2
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
http://www.nicoclub.com/FSM/240sx/19...general/EL.pdf
