Old 07-19-2010, 10:51 PM   #1
project_2fizzle
project_2fizzle's Avatar
project_2fizzle is an unknown quantity at this point
SR sr ac wiring
ok so it looks like my electric fans are wired to some kind of ac componet
theres a connecter connecting to the rerigerent next to my radiator and my fans are wired to the female connecter attached paralell to the same harness heres a pic im wondering where this wire goes if its to a relay or a direct fuse because my fans are no longer getting power and i need to fix w e is stopping it thanks the pic is crappy but should give u an idea of what im talking about
project_2fizzle is offline   Reply With Quote
Old 07-19-2010, 11:03 PM   #2
Sileighty_85
Sileighty_85's Avatar
That canister is the Filter Dryer (removes moisture and other crap from the system) On top of it is a pressure switch (should not have anything wired to it)
There is a plug in that area for the Stock E-fan but shouldnt be used to run 2 fans due to the system not being designed to support that high of an amperage draw.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-19-2010, 11:25 PM   #3
project_2fizzle
yeah who ever installed it tapped into a female loose plug located directly above the canister had no problems up till now i rather fix the problem then ignore it and wire it through something else you know
Old 07-19-2010, 11:36 PM   #4
Sileighty_85
well heres a crude drawing of how a E-fan relay system should be wired, if not using a DIF system, (there are other ways but heres one)
後輪駆動車1番
1986 SR86 - 200ish
Old 07-19-2010, 11:53 PM   #5
project_2fizzle
yeah i mite be a victim of ghetto tap ins thanks for the diagram but i guess i should fix this situation before i create a proper one so no clue where the female connecter leads??
Old 07-20-2010, 12:40 AM   #6
project_2fizzle
nvm i think they did do it through the stock fan i lookd at the fuse and it lookd a lil toasty imma swp it out and see what happens thanks man you were alot of help!
