2jz TDF Mounts in a S14 am I doing this right?
Hi guys,
I have a S14 i'm doing a 2jz swap. I've done everything and went to mount the motor in the car today. Upon mounting it I had a bit of an issue, or what I think may be an issue. I'm not sure If i'm using these mounts correct, the original owner of the mounts doesn't seem to know much either, and of course turbodave doesn't answer his phone or e-mail. Is the motor mounted correctly. If you have TDF engine mounts can you let me know I have a few other questions. Last edited by Djinfinit; 10-24-2014 at 07:36 PM.. |
the passenger mount is sitting perpendicular to the chassis whiles the drivers mount is sitting parallel or inline to the chassis. Not sure if thats they way it's suppose to be. IF anyone has TDF engine mounts and can calrify some things that would be helpful aswell.
