Old 09-07-2008, 12:28 PM   #151
crameur
crameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nice
320 hp + 100 Shot Nitrous
crameur is offline   Reply With Quote
Old 09-07-2008, 12:33 PM   #152
crameur
Originally Posted by s13dan View Post
It looks really good so far. No offense, but thats a lot of work for 320hp.
Yeah it's a lot of work But I did that swap Because it was a nice project , Putting a 6 Cyl in a 240sx ... Sounds Cool ... 320hp ... but a lot more torque than a 4 Cyl .... And if i go for single turbo in the futur ... This Block a lot More stronger than a Sr20 .... But Twins With Nirous Should Be Fun Too
Old 09-07-2008, 12:34 PM   #153
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
How did you clean the rotor so well? I have some EVO rotors I'd like to clean...
JRas is offline   Reply With Quote
Old 09-07-2008, 12:36 PM   #154
crameur
Originally Posted by tougestyle View Post
cmon frank keep my sister way out of this story :P anyway you are too young :P how the car goes on? does it start ? or the beast always sleep in the garage ? and who will tune that bitch 1jz? give me news
it's Gonna start very Soon , Most Everything is ready ... You know that swap Is a lot of Job ... it's not easy as putting an Factory Sr in a 240sx .... it's a lot of time and a lot of money ... i'll Take my Time For doing the Best Job as possible ... Anyway , The summer is almost Finished and i have a bike !! Ciao !
Old 09-09-2008, 10:15 AM   #155
crameur
resurfacing
Old 09-14-2008, 10:05 PM   #156
crameur
Update
The Wiring Is Done And almost Fixed ... I Got Ignition , Fuel , Fire And it Crank ...The Oil Pressure Goes Up ... I need To Fix Up The Fuel Lines, Few Vaccum , Coolant Hoses and This Bitch Should Start ... I relocated the battery in the trunk for more room In the front ....
Old 09-15-2008, 02:51 AM   #157
Driftn_MnSTrr
Driftn_MnSTrr's Avatar
Driftn_MnSTrr is an unknown quantity at this point
Thumbs up
sick sh!t man that's exactly the same swap i'm workin on !!!!
i got all the chassis , brake and suspension and mods done
(+ a kaaz 2-way) now it time for POWER !?!?!?!
send me info on where u got ur engine and mounts pls ? thnx
Driftn_MnSTrr is offline   Reply With Quote
Old 09-16-2008, 08:15 PM   #158
crameur
Pm Sent Dude !!
Old 09-19-2008, 03:55 PM   #159
army240
army240's Avatar
army240 is an unknown quantity at this point
Yahhhhh man! This will be a freaking sick ride We'll go burn some tires together man
army240 is offline   Reply With Quote
Old 09-19-2008, 04:03 PM   #160
crameur
Oh Yeah !!! Let's Rock !
Old 09-26-2008, 10:13 PM   #161
crameur
Thumbs up Update !
I Just received my waterpump pulley ... i worked on Heaters hoses and Radiator Hoses, Vaccums routing , and few others things ...
Old 09-26-2008, 10:16 PM   #162
crameur
Thumbs up First Start Up
Most Of All Is Fixed , So Here's a Little Video Of The Engine Running
Old 09-28-2008, 08:16 AM   #163
crameur
Oh Yeah !!!!!!
Old 09-30-2008, 02:43 PM   #164
tougestyle
tougestyle is on a distinguished road
fucking nice frank félicitation!
tougestyle is offline   Reply With Quote
Old 09-30-2008, 03:01 PM   #165
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
hey how did your run your battery relocating lines. i see that black bar with it connected to it and im interested in it if it simplfies things
Grenade180sx is offline   Reply With Quote
Old 10-03-2008, 04:23 PM   #166
crameur
it's a 150 Amps Bus Bar ... connected to the positive with a 2 gauge wire ... With that, You can Feed Your starter , Alternator and the fuseblock from The Front !!!
Old 10-03-2008, 05:13 PM   #167
Grenade180sx
so i can find these at a stereo store?
Old 10-03-2008, 10:09 PM   #168
crameur
yeah Maybe ... i Found That Bus bar Into an Alternator and Starter Rebuilding Shop ...
Old 10-07-2008, 07:33 AM   #169
thetopcow
thetopcow's Avatar
thetopcow is an unknown quantity at this point
Are you going to pass the wiring along the inside of the fire wall when you are done? I am looking in to the 1j swap right now and noticed the wiring for the engine goes through on the driver's side, which is the opposite of the 240sx. Also where did you get your info for wiring the two harnesses together? Is it insanely hard to two or just takes some time if you have the tools? thanks keep up the good work.
thetopcow is offline   Reply With Quote
Old 10-08-2008, 09:05 PM   #170
crameur
The Wiring Need To be modify To be more longer
Old 10-09-2008, 04:16 PM   #171
TPS240sxS13
TPS240sxS13 is on the path to ruinTPS240sxS13 is on the path to ruin
That is very Badass. I cant wait to see it all done.
TPS240sxS13 is offline   Reply With Quote
Old 10-12-2008, 08:00 PM   #172
crameur
Thanks Dude !
Old 10-13-2008, 10:46 PM   #173
mondojackal
mondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choices
Send a message via AIM to mondojackal
wow. sick project!! i love it. i've been looking into doing something a little more unique than the generic SR/KA-T, and this really piques my interest. well done, and it looks great!
what are you going to be using for engine management?
mondojackal is offline   Reply With Quote
Old 10-19-2008, 08:08 PM   #174
crameur
it's almost Stock For Now .. So i don't need any fuel management ... Yeah it's a pretty cool Swap But It's a lot of work !!
Old 01-11-2009, 05:13 PM   #175
crameur
My Project Is Almost Finish , Here Is a Video i made !
YouTube - BurnStitution Compilation
Old 07-07-2009, 10:35 PM   #176
VMP
VMP's Avatar
VMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to allVMP is a name known to all
wow that looks amazing! diggin the gold block!
hopefully i'll be doing this soon to my s14, but we'll see!
VMP is offline   Reply With Quote
