![]() Join Date: Jun 2011
Yes. definitely. You have to add fuel to keep running so it is running far too lean for some other reason
-Injectors may not be firing or may be clogged -fuel pump could be bad -clogged lines or filter are unlikely, but not out of the question I'm assuming you are poor like me. Check fuel pressure -I would get a $20 liquid filled gauge from summit racing, and install it between the fuel filter and rail or on the actual fuel filter. You will need either a barbed tee fitting with a 1/8th npt female port or a banjo bolt for the fuel filter with the same female port. Also you will need to use teflon tape on the gauge threads. Check injectors -Pull them out and look for any obvious signs of damage. If it looks damaged it is. Either send them in to get cleaned, get new ones, or clean and rering them yourself. Is it a stock engine? |
