![]() Join Date: Mar 2003
JWT ECU, 480 cc injectors, Revhard Mani, KA-T starter stuff.
I have the start of a turbo kit here for those interested.
1. JWT Ecu, tuned for the 480cc S15 injectors and stock Maf for stock motor. 2. 4x480 cc S15 injectors 3. One used Revhard Manifold 4. Two Turbos, one Garrett and one turbonetics ball-bearing unit. Both turbos are On-center exhaust housing so they fit the Revhard and clears the brake Master Cylinders. ARs are designed for the KA-T setup with the Turbonetics being bigger of the two turbos. Prices depends on if you buy them individually or the whole batch. JWT - $350.00 Injectors - $150 Garrett - $500.00 Turbonetics - $750.00 Manifold - $100.00 If you buy the whole thing together with Garrett turbo: $950 Whole deal with Turbonetics ball bearing: $1200.00. Pm me if you have questions. I will be willing to ship if you pay shipping. Do not forget this stuff is heavy. |
I have an on center down pipe from my old setup if you are interested. Is the reason you want to part with this stuff because you don't have the down pipe? This may serve to people who are thinking of buying your stuff too. trying to help out and not trying to be intrusive.
JDM Fashion isn't always good! |
I have an entire on center setup running on my car right now. This is excess stuff from changing out for upgrades. If someone wants to buy this stuff they should get your downpipe too.
It is a S14 ECU. I was running 9psi wastegate controlled boost. I did not dyno the car but it ran 13.8 in the 1/4mi with an automatic trans. trap speed 104mph. Estimated hp based on calculators online shows about 240 or so at the wheels. Tune does not take into account the turbo sizing. It is based off of the MAF, compression ratio and fuel available. At least that is what JTW explained to me.
At this point Injectors are SOLD. Turbos are Pending Sale. |
I bought it from Turbochargers.com a few years ago. It is the T04B series with the Ball bearing option upgrade. The AR is .63 I think. It is larger than the original turbo that came with my Turbo kit. The exhaust side is on-center style so it would mount and clear on a Rev-hard Manifold. I will grab the turbo over the weekend and post pics.
