Hi all,
My car is acting funny again... since yesterday, it takes quite awhile to start the car. It cranks, but it would not start till 5 seconds later. The day before only took 1 crank to start, which is weird too. Usually it takes about 3 crank to start. I've replaced the battery, cap and rotor, and spark plugs last week. Any idea guys? Thanks! |
![]() Join Date: Dec 2006
Coolant Temp Sensor
Normally if its the CTS it starts fine when cold and hard to crank when hot.
But check ECU for codes.
I will bring it to the shop in an hour to check the cel codes. |
Almost sounds like a dirty MAFS
So i just tried it couple times of starting the car earlier.
When the engine is still a little warm, it just starts right up. Also check the code from the ecu, it shows up code 44... oh well My friend who runs a shop also said that it could be the MAFS and coolant temp sensor; so i guess i will clean the MAF as well as the filter and change the coolant temp sensor. Thanks guys! |
So just a little update of my S13
I changed the coolent temp. sensor and the problem still exists... once i'm able to start the engine, i need to gas it a little or the engine would die. After about 3 seconds it idles fine... |
Mine is an auto so it doesnt have the starter relay.
One interesting thing i found is that if it is parked up hill, it's easier to start. On flat groumd its ok. Downhill takes forever. Would this explain something? |
