![]() Join Date: Sep 2009
![]() Feedback Score: 22 reviews
Brand new walbro+s13 install kit, digital gauges, inspiron duo, other goodies!
This is just a feeler, as I'm not sure if I want/really need this awesome device.
It's got a 10.1 inch screen, is flash-enabled (as its a fully functional netbook running windows 7 premium) built in webcam, 320gb hard drive, powered by an intel atom dual core n550 (1.5ghz) This thing is awesome, you can use the full keyboard just like an actual netbook, or you can flip the screen 180 degrees and fold it shut, and use it as a fully functional touch pad device. The color is "foggy night black" and will include all the original boxes/chargers (including all the jbl dock stuffs) So this feeler is for a duo+dock station, and I'd be looking to get $650 for everything. Here's a stock pic and a link to dell's site with more info (I'll post up actual pics when I get home) Inspiron ![]() Walbro 255 lph fuel pump, complete with an s13 install kit, brand new, never used (the pump or the install kit, I got them in part of a gas tank trade, and have no use for it as I had recently purchased another brand new one prior to said trade) $85 shipped. ![]() FEELER (I may run this, cause it's so awesome looking) Brand new Yashio Factory oversized water pump pulley, hopefully this shouldn't need much more of a description (it even comes with a yashio factory sticker!) : $145 ![]() An ALMOST fully complete (missing a single sensor!) s13 digital climate control swap. This setup is plug and play (just gotta connect two wires to power) IT'S MISSING THE JDM HVAC/AIR MIX MOTOR! everything else is there! $150 ![]() FEELER: Greddy/trust t517z turbo! T2 flanged, internally wastegated turbo, good for 380 hp (8cm exhaust housing). It's journal bearing and OIL COOLED ONLY (still has awesome response) I bought it used with less then 500 miles on it, and haven't used it (literally has ZERO shaftplay, interested parties are definitely welcome to come check it out) This is just the turbo itself for sale! $675, and I'm not in a rush to sell this, as I'll probably use it myself as soon as I get my other coupe up and running again. ![]() Here's more info on it from GReddy's site. GReddy And here's a brand new one: Greddy - Turbo Kit - Silvia - T517Z - Nengun Performance Someone come and get these, $30 each! Each board will come with 2 chips (you'll need someone to set you up with a tune, though) SR20DET boards (redtop/black top; not s14 sr motor; not type x sr motor) and I THINK they will work with KA motors I've got 2 of them left ![]() Fairlady Z, turbo boards (Z32); will also work on s14 sr motors! I have two of them. ![]() Newer SR20DET board (type x motor, s15 motor, s14 motor) ![]() brand new, still in the box glowshift red digital gauges. Oil temperature, and oil pressure. And a barely used matching water temp gauge These are all complete, with all necessary wires and sensors. I was gonna run these in my coupe, but it got totaled and now I'm going to go a different route. TEMP READS IN DEGREES CELSIUS AND PRESSURE IS IN BAR!!! $105 shippped for all 3 gauges! ![]() ![]() |
