1997 Subaru Brighton Impreza Build (not fully finished runs and drives)
Up for sale is my 4 year project. Was going to make it into a street/track car. Unfortunately with my new job I haven't been able to even really see it in the last 6 months and now my buddy sold his house which is where I keep it . Basics of the car is: 115k miles on it, 5spd 2.5rs swap, the 2.2 was completely refresh with all OEM nuts, bolts, gaskets with some upgraded parts. Every bushing on the car was replaced with either Groupn, kartboy or Whiteline. Due to a damaged radiator support being damaged I had a custom steel tube detachable support and now you can take the front end off with 8 bolts. Heres some of the parts list, plus I have more parts for a turbo kit I was piecing together (td04 off 04 wrx, walbro 255 kit, front mount, wrx oem header and up pipe)
Engine Custom Removable Radiator Support A/C Delete Rebuilt Power Steering Pump Full OEM Gaskets OEM Timing Belt/Covers 2.5rs Dual Port Heads OEM 12mm Oil Pump OEM Turbo Cast Water Pump Grimmspeed Phenolic 8mm Spacers Mishimoto Thermostat Mishimoto Lower Radiator Hose Mishimoto GC8 Aluminum Radiator Mishimoto Overflow Mishimoto Dual 12" Slim Fans Kartboy Crank Pulley Kartboy Pitch Stop Mount Group N Engine Mounts Braille 15lb Battery Braille Aluminum Mounting Bracket Relocated behind Passenger seat Tsudo Full Exhaust Drivetrain 98 2.5rs 5spd w/ Matching Diff Swap Transmission "Cocktail" Exedy Flywheel Exedy Clutch OEM Shifter Bushing (The bushing the shifter clips in to) Kartboy Short Shifter Kartboy 5spd Bushing Combo Kartboy Trans Cradle Bushings Turn In Concepts Shift Linkage Group N Transmission Mount All New Wheel Bearings/Hubs Suspension Raceland Coilovers (temporary) OEM Inner Tie Rods Whiteline Steering Rack Bushings Whiteline Anti-lift Kit Whiteline Ball Joints/Roll Center Kit Whiteline Front Strut Bar Whiteline Rear Strut Bar Whiteline Front Sway Bar Whiteline Rear Sway Bar Whiteline Front Sway Bar Endlinks Whiteline Rear Sway Bar Mounts Whiteline Rear Sway Bar Endlinks Whiteline Outrigger Bushings Whiteline Rear Diff Mount Bushings Whiteline Front Trailing Arm Bushings Whiteline Rear Trailing Arm Bushings Whiteline Adjustable Lower Control Arms Whiteline Subframe Locking Bolts GroupN Rear Subframe Bushings Brakes Rear Disc Conversion JDM GC8 WRX Non Abs Proportioning Valve PowerStop Single Pot Rear Calipers StopTech S.S. Brake Lines Motul RBF 600 Rear Parking Brakes Rebuilt Wheels/Tires XXR 530 17x9.75 Hankook RS4 255/40 Interior/Audio Radio/Speaker Delete Panels Painted Low Gloss Black Momo Hub adapter Momo Mod 07 TWM weighted shift knob Exterior 2.5RS Hood AeroCatch Hood Latches Prodrive Carbon Fiber Hood Struts Fiberglass Mafia Fender Flares Door Trim Removed/Holes Filled Asking $6,500 obo. Car has way more money then that into it so don't even bother with low balls. All the parts are basically brand new. They have less then 20miles on it but some parts have been on the car for a year or two. Car has been garage kept since I've owned it. Currently trying to figure out how to put pictures on here but it does have it's own instagram page https://www.instagram.com/gc22rs/ I know I'm forgetting a bunch of stuff but if you're seriously interested please reach me via text at 2zero1-6six3-5six19 |
