Old 05-27-2012, 11:38 PM   #1
Kevin920415
Kevin920415's Avatar
Kevin920415 is an unknown quantity at this point
Ka 5speed swap
I just want to double check before I start taking parts out.
92 hatch with sohc 5spd transmission vein converted
I have the following:
KAe transmission
Crossmember
Trans mount
Clutch set
Driveshaft
Lower harness
Clutch/brake pedals
I believe I need:
Flywheel
Clutch master cylinder
Stainless clutch cable
Is there anything that I'm missing?
Is there a harness for the clutch pedal?
Will automatic dust cover fit manual trans by bending or etc?
I'll appreciate your help and time.
Have a good one and happy memorial day to our troops
You drive DA 2 fo tay?
Kevin920415 is offline   Reply With Quote
Old 05-28-2012, 12:06 AM   #2
89s13sd
89s13sd is an unknown quantity at this point
5-speed transmission from an S14 (you could try an s13 if you want)
5-speed Drive shaft front and rear sections (this may differ if you have ABS/LSD)
Flywheel (new or resurfaced)
M/T flywheel bolts (A/T bolts are too short)
Clutch Kit (Clutch, Throwout bearing, Pressure Plate, alignment tool)
Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate)
5-speed Cross member
Clutch Master cylinder
Clutch Slave cylinder
Clutch hardlines
Clutch rubber line and dampener line (which you may want to remove anyways)
Clutch pedal assembly
5-Speed Brake pedal assembly or a cut brake pedal
Bellhousing bolts for a 5 speed bellhousing (some of the A/T bolts can be reused)
Bolts to hold Pressure Plate to Flywheel (same thread as bolts that hold shifter to transmission, but a tad shorter)
No harness for clutch pedal
#/f/tech-talk/387225...-progress.html
89s13sd is offline   Reply With Quote
Old 05-29-2012, 04:54 AM   #3
slammed04tsx
slammed04tsx is an unknown quantity at this point
isis makes a at/mt conversion line for about $50.
1991 NSX/ 1995 240sx RB25 Drift missle
slammed04tsx is offline   Reply With Quote
Old 05-29-2012, 05:00 AM   #4
Phlip
Phlip's Avatar
#/f/archive-faqs/211...peed-swap.html
And I write too!
