I have a s13 with a 5spd ka24de.so latetly I've had to jump start my car bcus for some reason my battery seems like it's being drained by the car.I jump start it and it runs and drives normal but for some reason it won't start at all today.the battery is fine bcus I checked it and it has all its volts.also when it was running it will bog in every gear.I could barely gain any speed and it will bogged alot.any ideas on what it could be guy.thanks
![]() Join Date: Feb 2005
Can you pop the clutch and start it? Any electrical issues, like no dash lights, or radio? Check your grounds, especially the one behind the head to firewall.
I used to have an issue with my battery being drained and it was the stoplight switch (brake lights). I parked in a garage and didn't notice my brake lights were always ON due to mis-adjustment. |
![]() Join Date: Nov 2010
If the car idles, probe the battery with a multimeter and make sure it's getting at least 14.2v with all accessories and lights off
