180sx 2way problem
Hi im have a 180sx half axle and is trying to swap to a 2way nismo in a 180sx pumpkin but the right side is too long? What can i do to fix this problem? It is a five bolt halfshaft
![]() Join Date: Mar 2009
Is the stub shaft from a vlsd differential? I believe most aftermarket lsd's require the use of open differential stub shafts.
Also make sure you don't have the sides mixed up one side is longer than the other. |
Yes stub shaft is off my 180sx vlsd. The left side slides right into my new 2way 180sx pumpkin, the right side will not. Left side goes in no matter which side.
Wat other car has a short five bolt stub? |
