#2191 |
#2193 |
![]() Join Date: Feb 2011
cody i have a question, would the exhaust housing with the 44mm external wastegate (.72ar) also be a viable option if one didnt want to modify the exhaust mani?
EDIT: nevermind, looking at it the wastegate flange is on the wrong side of the turbo. EDIT2: nevermind, im dumb, it would work, just wondering if its viable. Last edited by tabasco122; 09-17-2011 at 12:03 AM.. |
#2194 |
![]() Join Date: Mar 2007
Trader Rating: (31)
So,with what boost I'd like to run (18psi+/-)setup:
2871 .64 ,256 Poncams, Apex'i HG,BC valvetrain,Tomei FPR, Z32 maf Enthalpy Tune (once I decide inj size) What Size Injectors should I run - 740cc? will 555's be safe or to close to Full duty??? I'd love about 350+/-whp,...possible with this setup?
z-tERty-2 |
#2195 |
![]() Join Date: Sep 2005
You can do 350hp with 555cc injectors. Don't let anyone tell you different. It's all in the tune. but why pigeon hole yourself? You'll be worrying about over boosting and anything related to bad fuel quality. I know I did. Knowing the weakest link was my injectors. I opted for the sard 850's. So get the 740 injectors, They seem to be the go to injectors anyway. That would also stop the massive flaming I'll get for saying 555cc's are good for 350hp
You'll most likely be using that retune service Enthalpy Offer's, so have a way to datalog those AFR! ![]()
#2200 | |
![]() Join Date: Apr 2011
here I even posted the link for you no let all the good karma in the world come to me wait this is not reddit LOL 1 - HKS 740cc Injectors - Nissan SR20DET 2- I can't find the amazon link right now but that's where i got mine from for $560 shipped all together |
#2202 | |
![]() Join Date: Jun 2008
![]() #/f/tech-talk/298993...ind-out-9.html
1990 240sx fast back ![]() SR20det GTXX71R Sips on E-85 ![]() 1998 S14 Kouki ![]() KA24de Bone Stock...... 2004 Lancer Evolution Last edited by S13 curtis; 10-01-2011 at 06:45 PM.. |
#2203 | |
Suddenly 550cc turned into 630cc which made all the difference and even at 550cc never had a hit of knock. |
#2205 |
![]() Join Date: Aug 2010
hey guys i have finally finished my setup and got it running well and was wondering if anyone can give me a ball park to what my whp would be. Also where would be a good place to get it tuned in California once im ready to get some dyno time to fine tune it. My goal is 350-400whp
Setup: (91 oct) forged pistons(i believe super tech) metal head gasket BC Stage 2 cams(264/264) GT2871r .86 Greddy Manifold 740cc Denso Z32 MAF EFI specialist tune 3" exhaust Isis Screamer Dump(wondering if this is why my turbo isnt AS responsive as other setups) Greddy RAS |
#2206 |
![]() Join Date: Jan 2008
CThose are some nice welds. Don't you think you should have opened it up to both runners all the way. Since youhave that crack and the little hole any how. Looks nice though. I am sure it will still bebetter then stock
My Twin Scroll Gt30r Sr22det Build |
#2207 | |
1990 240sx fast back ![]() SR20det GTXX71R Sips on E-85 ![]() 1998 S14 Kouki ![]() KA24de Bone Stock...... 2004 Lancer Evolution |
#2209 |
I'd probably make a decision on that hole and crack before install. That chunk could potentially kill your turbo. Not everyone's build plans include a cyanide pill!
#2210 |
I like my BC 264 cams
#2211 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
SUpposedly the crack is normal... I am kinda thinking about dremeling it out though...probably the extrude hone material took alot of material away also.
#2212 | |
#2214 | |
From what I see, sometimes people get a good pair and some get awful ones. Sometimes they need to be degree'd, your's seem to have came out good.
#2215 | |
#2216 |
![]() Join Date: Sep 2009
Sup guys,
I was thinking of getting a stock manifold and the extrude-hone process but I cant find someone using this process around here... has anyone tried porting the stock manifold? or any suggestions? |
#2217 |
![]() Join Date: Nov 2003
Well, I got my newly tested Nismo 740cc injectors, Isis Z32 MAF, and freshly tuned JWT ECU installed, and it fired up the first time, but rough, real rough. Checked the wideband...maxed out at 10.0 on idle, and under light load.
Ran it around for a little bit, figuring it was just from fuel falling in the cylinders when I replaced the injectors. It got a bit better, but never cleared up. So I checked the ground on the MAF, and cleaned it up better, that made little to no difference. Then I completely disconnected the body ground on the maf, and hte car seemed to idle fine...13.7-15.0 at idle, and light throttle. Which is weird, because it didnt do that at all until the ground was disconnected. :/ Then @7psi it would hang around 13.5ish which isnt terrible, but much leaner than I wanted to see. But I remember reading that it would run a bit lean under light boost like that. So I increased boost to 15psi, and it would read around 15AFR....not good. So I only did that once, and didnt try it again. Got back home, and tried grounding the MAF again while still running, it immediately got really rough, and went back to 10.0. FML. Anyone have any help? ![]()
-Kyle |
#2218 |
^ you sure you got the right tune?
#2219 |
I can only assume so, I sent JWT the specs, and my factory ECU. The invoice says 740's and Z32, so I can only imagine that it was done correctly. :/
-Kyle |
#2220 |
![]() Join Date: Oct 2004
How does the WG work when the engine torques? I have motor mounts and I tell you at 350+ HP, the engine torques no matter what...
Is there room to compensate for that? -Ken
Turn and Burn!
