Old 04-11-2003, 11:39 PM   #1
1BADS13
1BADS13 is an unknown quantity at this point
Clutch Pedal Slack
OK I HAVING A PROBLEM WITH MY PEDAL SINCE I HAVE CHANGE MY SLAVE CY. AND MASTER CYL. (IT WENT OUT ) I HAVE EITHER TO MUCH OR TO LITTLE SLACK IN MY PEDAL (ADJ. ON MASTER CYL. IS VERY TOUCHY (DID USE AFTER MARKET PARTS ) HAS ANYONE RAN ACROSS THIS PROBLEM OH AND THERES ABSOLUTLY NO AIR IN SYSTEM . THANKS FOR ANY COMMENTS
1BADS13 is offline   Reply With Quote
Old 04-12-2003, 02:04 PM   #2
gregsr20
gregsr20's Avatar
gregsr20 is an unknown quantity at this point
pressure plate, low fluid, air in lines, low pressure check all, easy on the caps lock, that means you are yellin at us
fast cars are dangerous, save lives drive HONDA'S
gregsr20 is offline   Reply With Quote
Old 04-12-2003, 03:08 PM   #3
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
are you talking about free play in the clutch pedal. if you are just go to the pedal and there's a rod that goes from the top of the clutch pedal through the firewall. just loosen the lock nut and adjust that to spec, i can't remember what spec is but check in the fsm it will be in there. don't forget to retighten the locknut, but not too much i think the fsm says like 16ftlbs or something small like that.
Tim
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
