![]() Join Date: Jan 2005
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
$85 Shipped Walbro Fuel Pump w/ Kits *** Wiseco $455 *** COSWORTH And TOMEI !!
![]() S13 and S14 Walbro Fuel Pump Kits GSS341 with Install Kit For SR20DET Pump + Standard Install Kit = $85.00 Shipped (Items: 1+2) Pump + Install Kit + Longer Filter Sock = $93.00 Shipped (Items: 1+2+3) Purchase the following Items ! 1. Walbro GSS-341 255 L/H Fuel Pump 2. S13 / S14 Install Kit (short socks, wiring and fuel hose. 3. Longer Socks (optional piece, only order if you like to have longer filter socks) Free shipping to any US States, excluding PR. Wiseco Piston And Ring Set - $455.00 Shipped - available in 86.5mm or 87mm (SR20DET Engine) - available in 89.5mm, 90mm or 90.5 mm (KA24 Engine) ARP Head Studs Kit For SR20DET - $151.99 Shipped Eagle Forged Connecting Rod For SR20DET (S13, S14, S15) - $399.99 Shipped Thank you! Last edited by Ravspec; 05-04-2010 at 09:04 PM.. |
#2 | ||||
Trader Rating: (25)
TOMEI N2 Oil Block Adaptor ** Absolutely necessary for Oil Pressure sensor attachment - $235 Shipped
![]() ![]() Quote:
![]() Quote:
TOMEI SR20DET Cam Pulleys - $360.00 Shipped Per Pair TOMEI SR20DET Rocker Arm Stopper - $75.00 Shipped Per Pair TOMEI SR20DET Head Gasket - $259.00 Shipped (Click Here To See Compression Ratio / Thickness Data) TOMEI SR20DET Connecting Rod Set - $612.00 Shipped Per Pair TOMEI SR20DET Forged Piston Set - $1299.00 Shipped Per Pair TOMEI ARMS Turbo Kit (SR20DET) - 380 HP (B76520 Arm Turbo)- $1959 Shipped Quote:
![]() Last edited by Ravspec; 04-04-2010 at 10:46 AM.. |
Trader Rating: (25)
paypal has a comment section, so is the shopping cart after you sign up.
OR leave a note here (give your full name) and we will process it with the zilvia.net discounts ! Mark. RavSpec |
Trader Rating: (25)
finally got my acct back
zilvia.net was having issue with my accounts. Been out since Monday.All the pumps are shipped and should already arrived. I still have a few left if anyone are interested ! RavSpec |
#17 |
I'm having a little trouble finding the right information. Is the install kit specifically for the S14 or is it just the longer sock that makes it work properly for the S14?
#24 |
![]() Join Date: Sep 2003
How long is this going for? I really like the price of those pistons but some other things are first...
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
#29 | |
Bandwagon.
same question. |
#30 |
Trader Rating: (25)
The S14 fuel pump is not listed as an application from Walbro but since it was a popular demand we did some R&D and found that a larger filter to replace the shorter filter on the 400-766 kit to make it reach fuel from the bottom of the tank.
