2jz into zenki 240 questions
Turning my zenki 240sx into a 2jz-gte swap project this winter and had a couple of questions for ppl with experience in this swap
1. Is the 2jz-gte ecu ok to use with the r154 2. How much hp/tq is the stock r154 able to hold 3. " " s14 rear able to hold Any tips on this swap would b very helpful |
#3 | |
![]() Join Date: Apr 2007
you could push a R154 a little higher then 500. but thats a good basic number. Merlin makes upgrades for the r154 you can find it on driftmotion's site. stock rearend should be ok with some sort of LSD up until the 500+? area. seems people are 50/50 with how there rear ends hold up.
