Will a TH400 fit into a S13
I am doing the v8 swap and building a mild LS1 engine. I would like to use this trans but i need to make sure it will fit. I don't mind doing a alittle "messaging".... I've searched btw and nothing....
Thanks |
![]() Join Date: Apr 2010
you be doing a lot of massaging. For shits and giggles when i was swapping my sohc to a dohc-t i through a dummie 350 block camaro bell housing with th400 in it to see if it would work. also tried a th350, corvette 4 speed and a rock crusher
and all im going to say is that youve got a lot of work ahead of you. with fab you can fit anything into an s-chassis if you go for it please take lots of pictures and document everything. Im curious how you end up doing it |
![]() Join Date: Sep 2007
If nobody has input on this... than that's even more reason to go for it and make it happen and like stated above... pics and document everything!!! Experimentation means progression!
![]() Join Date: Apr 2007
i talked to nismoknights on here about this a while ago, and he was running a TH350 and he said it "fit" i've seen a few other 2JZ/TH400/TH350 guy's running them so it shouldnt be much of an issue.
i would say its nothing a hammer couldn't take care of.
i have built hundreds of th400s they are full hydraulic tho.will the bellhousing work? if not try advance adapters, i would go with a th350 tho bc of the weight. both re creap to rebuld and very simple just get a haynes tech book. and to make it work fab up a x member and buy a ratchet shifter they are cable actuated. andon the plus side the trannys are everywhere and can be found for cheap
SEMPER FI |
