Twin disc with Stock s13 clutch assembly help!
Hey guys I have a s14 that was auto/manual swapped. Currently has a SR, stock tranny with a CC twin disc clutch.
The car is drive-able but the problem is that my pedal travel is short (doesn't hit the floor) and the smallest movement in clutch travel makes a huge impact. For example, simply taking off in 1st gear smoothly is a challenge. I believe it has something to do with my s13 clutch assembly set up, possibly not enough pressure? I've looked around and emailed CompetionClutch, looks like a larger slave cylinder may help, Im thinking about the 300zx TT slave. Any info on this would help, is it a direct bolt on?
Its hard to explain the problem but its basically hard/pain in the ass to drive. I appreciate your help!
Joe
