s13 s14 wheel bearings-outer race the same?
I searched and I could not find. I'm doin a five lug swap using s14 hubs, but I'm keeping the s13 knuckle because it better accomodates my super angle kit. since s14 inner bearing races are too big for the s13 knuckles, can s13 bearings press into s14 hubs?
ive been looking into the same question what ive come up with is between the 2 front hubs is bearing size aswell as a shield around front hub attached to dust sheild, looks like diameters may be different so by trimming off shield and replacing bearing for correct application it should bolt up correctly. as soon as i get a chance im goin to try swaping my vert 5 lug with my s14s 5lug to see if thats the case between my 2 cars.
