92 240sx black top after boost problem?
Whats up guys i have a black top sr running a hks ssqv ON THE COLD SIDE and im having problema with after boost idle. The car runs sound and pulls hard just after boost (7psi) when comeing to a stop or pushing the clutch in its idles way down / cuts out. I have never had this problem until i tried sliding the car a bit and it cut off on me. Everything is OEM cept the inter cooler and pipeing and BOV which is brand new. Any sugestions..i dont think recirc the bov is the problem cuz it has never done that when taking it to the strip to get quater mile times only after i drifted it?
![]() Join Date: Jan 2011
Its the bov. Stock ecu is tuned for recirculation. What you can do is try and let the car go into full vacuum (let off the gas for a moment) before putting into neutral, or recirc it.
Well thats the thing it ran perfect before i drifted it like i could pull hard and stop etc etc no problem its only now after i drifted it i dont get it
