2JZ-S13 Silvia Build
Been a long time lurker, but never really posted. I've owned my 1990 Nissan Silvia K's car for 10 years this November and brought it from Japan with 41,000km.
If anyone is interested in the complete build start to finish, it could be found here. http://forums.nicoclub.com/2jz-s13-f...t491306-60.htm The point of this thread is focused on the recent mods and where the car is going in the near future! That being said, here's a small recap and parts list to date. Toyota Aristo 2JZ-GTE Toyota Soarer R154 transmission Tech2 Mounts/Crossmember/Driveshaft Tech 2 Billet Pulley Kit OS Giken TS2BD Twin Plate clutch OS Giken Movement Kit Precision Turbo 6162 HKS 50mm Wastegate w/ Dump Pipe HKS 200mm Super Flow Intake HKS Adjustable Cam Gears HKS Fuel Rail Injector Dynamics 1000cc SARD RJ Fuel Pressure Regulator Walbro 450LPH Fuel Pump Greddy 10 Row Oil Cooler w/Filter Relocation Greddy Intake Plenum 80mm Billet Throttle Body Blitz Blow-off Valve Blitz Nur Spec R Muffler 3" Custom Stainless Turbo Back Exhaust Flex-A-Lite Electric Fans Koyo Radiator Circuit sports Coolant Tank Radium Engineering Oil Catch Can ChaseBays Power Steering Can Volk TE-37's F-9.5X18 R-10.5X18 +15 Ichiba 5-Lug Conversion GTR R33 Calipers/ Rotors GTR R32 Brake Master Cylinder Vex Performance 5/8 Clutch Master Cylinder Vex Performance Custom Clutch Hose RigidRacing Clutch Master Cylinder Adapter Custom Stainless Brake Lines KW Variant 3 Coilovers KW Clubsport Adjustable Camber Plates K-sport tie rods/ends Greddy Front/Rear Upper Sway Bars Haltech Platinum Sport 2000 Haltech 3 Bar Map sensor Haltech Air Intake Temp Sensor Haltech Boost Solenoid Haltech Idle Air Control Valve Defi VSD- Heads Up display Innovate Motorsports LM-2 Wideband Origin Aggressive Aero Kit Black w/metallic gold flakes D-max Smoked Tail Lights GTR Front Grill PoorForm License Plate Adapter As of World of Wheels February 2015 Every thread anti-seized and all joints have been siliconed This is why you don't do electrical work just to hide it, you end up with a gluey disgusting mess once heat is applied. Functional yet aesthetic Improved coolant lines My new boost controller via Haltech with 270° Sweep Fuel Lines changed from PTFE to regular -6 AN and mounted with Aluminum clamps thread-serted into chassis Start of heat barrier and shield project Mock-up of heat shield Projects for this week: Radium Engineering Catch Can Haltech Idle Air Control Valve Injector Dynamics 1000cc A short pull after a bit of street tuning, dyno video in a few weeks |
Which Equips do you speak of? Thanks dude, its come a fair ways.
Project got alot more serious in the last month, I've redone a few things, went a bit more custom and acquired some pretty wicked parts! Firstly would be my oil cooler project. The goal of this was to: 1. Find a secure and aesthetically pleasing way to mount everything 2. Increase airflow over the cooler core Shaved a bunch of weight off my block-off panels by switching to Aluminum Created some nice ducting to channel air Start of my STACK 8130 race cluster project Turbo side has received some serious attention. Borg Warner EFR 8374 0.92A/R IWG w/ Forge Motorsports Actuator and Full Race BOV. Proseries EFR T4 Divided manifold Downpipe has been remade in 3.5" Stainless and wrapped with DEI with proper O2 bung placement. |
