rb help
have an rb s13 ran clean real good over heated turned it off let it cool down put water4 drove it for a bit and i think the motor locked or something cuz if i try to push start it locs my diff. motor dont crank sounds like it would b da starter wen i turn the key but y would the wheels lock if i try to push start
wel it went like three quarters way dude and it had like a knok but for sure n da head i was driving after n it just shut off n me n turned on again then never turned on again but dam idk hope motor aint locked
![]() Join Date: Feb 2006
Sounds like something inside of it broke. You need to pull it apart. Don't do any further damage.
BUT there is a tech section. I must be getting old and crotchity... |
It's kinda hard to tell what you're saying...please toss some punctuation in there. Anyway, if there was a knock I would not have kept driving it but it's too late now. Like I said, try to turn the engine over by hand to see if it does, you feel any resistance spots, etc. If the sound was coming from the top end, you could also pull the valve covers and see if anythings out of place. Gotta turn some wrenches at this point to figure it out.
-Aaron |
