Old 02-06-2012, 01:35 PM   #1
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
S14 SR spun bearing long block toda/rps/nismo/kazama stuff
S14 SR20DET, spun bearing special, parked and pulled motor as soon as it happened, complete head minus valve cover, with correct ARP head studs and apex'i head gasket with less than 500 miles on both. Block is missing lower oil pan/baffle and exhaust stuff, intake side is complete except injectors. No accessories included. Rather sell together, don't really want to separate, but may split up if have buyers for both. Can arrange shipping LTL Freight in southeast region real easy.
$450 for head/block combo with head studs/gasket
SR RPS Max pressure plate with street disc, disc has some life left in it, but you can get a new disc from RPS for $115. Will take $125 for both
SR transmission shim plate - $30
Newer VTC solenoid, little over 1 years use - $50
SR CAS - $125
SR Starter - $75
Kazama motor mounts - $140
Mirage is offline   Reply With Quote
Old 02-06-2012, 07:42 PM   #2
EnemyS15
EnemyS15 is an unknown quantity at this point
I'll take the nismo tranny mount . Flat rate ship it to me to 33612? Text me and let me know 813-345-6180 ....
EnemyS15 is offline   Reply With Quote
Old 02-11-2012, 01:20 AM   #3
Mirage
edited and bump
Old 02-11-2012, 07:48 AM   #4
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
how much for the block/head combo minus the head studs and head gasket?
sidewaysil80 is offline   Reply With Quote
Old 02-11-2012, 08:23 AM   #5
97nismo
97nismo's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
ill take the starter.......and i am sorta local
Feedback:
#/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 02-18-2012, 02:30 PM   #6
Mirage
Another clean up bump
