FS - JWT S4 Cams for SR20DET
Hey guys!
Pair of JWT S4 Cams with 1200 miles on them. Pretty damn aggressive cams and arguably one of the top on the market. I used to run Tomei Poncam type r's which made quick solid power, but top end strength wasn't comparable to the brute power these s4 cams shot out. I wouldn't recommend them for you ball bearing boys running small a/r's (2871r .64ar, GTX2876R .56ar), as the s4 cams mates up MUCH better to the fatter turbos. 3071r - GTX3071R). Here's a couple reviews from some SR guys (NA and Boosted) Camshafts BC vs JWT - SR20 Forum BC S2 Cams vs. JWT S4 Cams - SR20 Forum Homey hooked it up for $500 brand new a year ago so I'll pass the savings onto you. (MSRP$550). Willing to let them go for $350 picked up. Can ship at buyers expense. Located in Anaheim Ca |
Pending sales to Marc Anthony... I kid.
@TheRealSy90, what was your setup and what kind of power did you put down? I'm curious on the numbers because these JWT cams only saw the butt dyno. The Poncams dynoed a modest 350hp at 14lbs with a 2871r 64a/r, but a quick street tune with these cams felt much stronger. |
Just in an NA SR, drop in, ebay headers, with a ROM tune... made 152 WHEEL HP on a mustang dyno, rev limit was still at 7,200 RPM as well NA SR20s are rated at only 140HP AT THE CRANK... These cams are hot!
![]() Join Date: Mar 2009
If you search Redtop sr20 s4 cams Isis straight pipe on YouTube you should find a video of my sr running with these cams. It's a coupe.
Sent from my iPhone using Tapatalk - now Free |
![]() Join Date: Jan 2003
I know s3 have been run on stock valve train. Is the s4 too much lift for stock heads?? If not I might have to swoop these up!
TEAM SKIDMARKS Carbon black S13 SR Coupe |
Great seller I'm glad I don't have an sr or else I'd buy them. Bump for kyle
#19 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Great price for a awesome cam!
#22 |
![]() Join Date: Jun 2003
Trader Rating: (129)
Definitely the ideal cams.
#24 |
