![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Its out of a Q45 and its OEM NISSAN, condition is good and low milage 74K on the VLSD....reason I deleted thread is because I may decide to sell the ring and pinion only as a set but if your really interested lmk
![]() Join Date: Dec 2008
WTF? That ouput shaft is the first i've seen.
Isn't it on Nissans and Infiniti, 5 bolt and 6 bolts but the 6 bolts are suppose to be in 3 pairs of 2? I've never seen 6 bolts evenly spaced out like that...crazy. That output shaft won't work with 240sx, or 300zx or j30's axles. |
Trader Rating: (40)
The axles you needs with the 6 bolt out flanges are G50 Q45 drivers side and Z32 TT drivers side. .................................................. .................................................. ........................ Output flanges S13/S14/J30 (2x3 bolt) = 29 spline count Z32 NA/J30 (5 bolt) = 29 spline count but dont work correctly in a S13 VLSD (they stick out to far on one side G50 Q45 (6 bolt) = 30 spline count Z32 TT (6 bolt) = 31 spline count FGY33 Q45 (5bolt ) = 30 spline count (these will work in the G50 Q45) |
