| Group Buys Dedicated Forum for Group Buys. |
Drifterella
ProSport Gauge Sale! Inventory InStock! Gauges starting at $34.00
I just got a shipment of ProSport gauges in today. All guages listed in stock and ready to ship, other gauge requests are available for special order for the same discounted price.
The 270° dial sweep provides quick, one glance accuracy. Track tested and race proven, these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment. All Electric Gauges perform a dramatic opening ceremony with a full pointer sweep and self check each time the vehicle is started. No controller needed! Performance 52mm Gauges: Blue Boost Gauge (mechanical) - Super Blue 52mm $35.00 Oil Pressure Gauge (Electric) w/sender - Super Blue 52mm $40.00 Exhaust Gas Temperature - Super Blue 52mm $87.00 Oil Temperature Gauge (Electric) w/sender - Super Blue 52mm $35.00 Water Temp. Gauge (Electric) w/sender - Super Blue 52mm $35.00 Amber/White Boost Gauge (mechanical) - Amber/White 52mm $36.00 Oil Pressure Gauge (Electric) w/sender - Amber/White 52mm $40.00 Exhaust Gas Temperature - Amber/White 52mm $89.00 Out of Stock, On order Oil Temperature Gauge (Elec.) w/sender - Amber/White 52mm $37.00 Water Temp. Gauge (Elec.) w/sender - Amber/White 52mm $37.00 3 3/4" Tachometer with shift light $47.00 Green/White Boost Gauge (Mechanical) - Green/ White 52mm $36.00 Water Temp. Gauge (Electric)-Green/White-52mm $36.00 Oil Pressure Gauge (Electric)-Green/White 52mm $35.00 "Prosport Gauges is proud to roll out our newest line of PREMIUM Series Gauges featuring fully programmable Warning & Peak Recall functions. These new Gauges use Precision Stepper Motor Driven pointers for exceptional accuracy. Coupled with 2nd generation Electric Senders for unprecedented precision. This newest series of gauges features a daisy chain wiring system to make installation easier. For multiple gauge installations only the first in the series needs to wired for power, ground & Color choice. Each additional gauge can be powered using the supplied daisy chain wire." Peak Hold Gauges come with mounting cups. Peak/Hold 52mm Gauges: Amber/White Boost (Electric) Warning & Peak Hold $74.00Out of Stock, On order Oil Pressure (Electric) Warning & Peak Hold $97.00Out of Stock, On order Water Temp. (Electric) Warning & Peak Hold $64.00 Green/White Boost (Electric) Warning & Peak Hold $74.00.00 Out of Stock Oil Pressure (Electric) Warning & Peak Hold $89.00 Water Temp. (Electric) Warning & Peak Hold $62.00 Gauge Accessories 52mm Mounting cups $9.50 Water Temp Sender Radiator Hose Adaptor 32mm-Gold $24.00 PM or email me at [email protected] PM me with zip code for shipping quote. All orders of atleast 3 gauges include free shipping. PAYMENT All Iowa residents are subject to 7% sales tax. Paypal is [email protected] Postal Money Orders also accepted Cash in person Peak/Warning Components |
![]() Join Date: Apr 2006
i snet you a Pm
2015 Subaru Outback Overlander - Wagonofdoom |
Drifterella
To clarify a question asked in a pm.
Also, the Mechanical Boost Gauges do not do the opening ceremony. A non peak/hold electric boost gauge would be $50.00 and it would take a couple days for me to get them. I should have some of these in stock in a couple days. |
![]() Join Date: Jun 2003
Hmmm, might have to make an order in the next couple weeks, planned on picking a couple of these up.
Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
Drifterella
These prices will last until Dec. 31.
I will still have them on special after that, but because of higher material cost ProSport will be raising their prices on the first of the year. |
Drifterella
I haven't personally experienced the boost gauge being off. The gauges come with a 1 year warranty and if this happens to you I will swap you out for a new one as soon as possible.
Here is what ProSport has to say: "These new Gauges use Precision Stepper Motor Driven pointers for exceptional accuracy. Coupled with 2nd generation Electric Senders for unprecedented precision." |
#20 | |
Drifterella
Otherwise I can get oil filter sandwich plates for $37.00 |
#22 |
![]() Join Date: May 2005
heres a little video that i found on the prosport website.
gives a good look at the diff colors and the start up. http://prosportgauges.com/media/progauges.mov ordered 2 guages last night and will be recieving them tommaorw, couldnt be happier with the service from S13FREAAAK SS |
#23 | |
![]() Join Date: Jan 2005
Does the sandwich plate come with outlets for fittings for an oil cooler setup? Does it come with a built in thermostat? S14 SR uses a different oil filter and S13/ka. |
#25 | |
![]() Join Date: Jan 2004
ps get back to me about the apillar pod ![]()
s13 parts fs:#/f/showthread.php?t=193416 sr parts fs: #/f/showthread.php?t=193399 s14 parts fs:#/f/showthread.php?t=193420 180sx part out #/f/showthread.php?t=203711 |
#26 | |
Drifterella
If you are looking to retain the oem sending unit your best bet would be the oil filter sandwich plate. It would give you two extra ports so you would be able to run a oil temp sensor and the pressure sending unit. I'm sending you a pm on the pillar pod right now. |
#27 | |
Just get the gauge. |
#29 |
Drifterella
Yes they have some available. Here is the 60mm gauges available, I don't have them in stock yet but I can order any of them and have them shipped out within 3-4 days. 60mm Amber/White Gauges Boost Gauge (ELECTRICAL) -Amber/White-60mm $61.00 Exhaust Gas Temp. Gauge (electrical)-Amber/White-60mm $104.00 Oil Pressure Gauge (Electrical)- Amber/White-60mm $50.00 Water Temperature Gauge (Electrical)-Amber/White-60mm $50.00 Oil Temperature Gauge (Electrical)-Amber/White-60mm $50.00 60mm Premium Series-Warning & Peak Amber/White Gauges Boost (electrical) Warning & Peak-60mm $83.00 Oil Pressure (Elec.) Warning & Peak-60mm $100.00 Exhaust Gas Temperature (Elec.) Warning & Peak-60mm $112.00 Oil Temperature (Elec.) Warning & Peak-60mm $73.00 Water Temperature (Elec.) Warning & Peak-60mm $73.00 |
