![]() Join Date: Mar 2014
sway bar godspeed or isis
so im been searching around trying to get reviews on both sway bars
i cant decide which to get i have chose these 2 setups due to budget isis is 27mm godspeed is 28mm rear and 30 front anybody have some feedback on how these feel thanks -kevin |
#4 | |
GM2 (SW/AW)
Go with Isis then. nearly the same quality just depends on what Godspeed or Isis part you're buying.
ok
does the sizes make alot difference? 30 front 28 rear and 27 front and rear ill just probably go with the isis like he said above and i can try different setups later on im just trying to choose a decent setup to start with thanks for the help guys |
#6 | |
GM2 (SW/AW)
Size does matter, I don't remember the stock sizes anymore but unless you're doing some track stuff why run bigger? I mean sure go bigger just for the stiffness but it's not really necessary to go the biggest right away unless you feel so.
Just my opinion.
i plan on making it my daily and go to my local track here and there so i think i am going with the isis i already have 32 way megan coil overs that i got with the car new and i have replaced every bushing on the car with engerysuspension so i think it should be good |
Neither, go with a proven sway bar, not cheap garbage someone did absolutely no engineering on.
My SR20VET |
![]() Join Date: Jan 2012
im with jr_ss. Quality always beats out price. From what i have seen the difference in price for sway bars really isnt that much different between the brands.
#12 | |
. I am in agreeance with jr as well.......... |
It's not tough times, it's people being ignorant and cheap. Everyone in this "scene" wants something for nothing. The knock off companies catered to their demands. Now you have a market flooded with shit products because they copied the real people that put the time and effort in to bring you great "engineered" pieces.
My SR20VET |
#15 | |
and your are correct. its funny cus i have not cheaped out on anything on my car its either oem or better i should just save some more money those whiteline sways bars look nice. |
#17 |
![]() Join Date: Jun 2007
Pssh! Don't be so hard on yourself- You're not cheap
![]() ---------------------------------- Godspeed or Isis... Diarreah or Gonnoreah... which do you prefer? ---------------------------------- OP- Congrats- the Whitelines LOOK nice... but do they DO what you want them to do??? Do you really NEED them? Have you tried replacing your current sway bar bushings & end links? Makes a world of difference and quality urethane bushings are very inexpensive (Energy or RS-R- NOT Megan!!!). My rear sway bar is OEM 180SX. Installed RS-R bushings & Energy end links (both made by Energy IIRC)... Made a very nice difference with no need for some ginormous sway bar. For effect, I had it powder coated silver- simple, cheap, pretty and effective. However, up front, I did the opposite- I changed the OEM front sway out for the big Tanabe SUSTEC w/urethane end links... Guess what? Between that, the Nismo power brace, the fender braces & huge preloaded tower brace; I pretty much welcomed myself to very linear, flat turns.... Yay right? Wrong- a world of understeer- gotta really work it in the tight turns to get decent weight transfer with the coilovers. Be careful what you wish for...
If you want less understeer you need to go with a stiffer rear bar. Most guys that track their car run the OEM front bar and an upgraded rear. I know backwards from what you would think.
My SR20VET |
#19 |
thanks for comments
mikester your right i guess i should mess with what i got now and go from there i do have energysusepnsion everything and dam it feels like a different car except the sway bars haha i see that the whiteline has the 3 adjustments on the ends to stiffin or make the sway bar soft correct me if im wrong that will let me miss with the settings and figure out a nice layout for me |
#20 | |
![]() Join Date: Apr 2004
Your theory holds true for something with a nice suspension geometry and balanced roll stiffness like a Formula car.
#21 |
Both front and rear are adjustable to "tune" your setup. I suggest purchasing the upgrade Ball joint style end links vs the the stupid S-bracket design.
My SR20VET |
#22 | |
My SR20VET |
#23 |
I am very happy with my Suspension Techniques sway bars. I think they are $299 at Enjuku. They are not quite as thick as the options you listed with 28.5mm front and 20.5mm rear. Not sure what car you drive, but I think an S13 non SE was stock with 24mm front and 15mm rear. I felt a big difference from stock to my ST bars.
I think that the Godspeed is a bit overkill at 30mm...seems like they are just overcompensating since nothing of theirs seems to be engineered. I agree with most above, quality is always better than price. I typically try to do a step or 2 above the Isis/Godspeed stuff, even though I have a small budget myself. |
