95 cluster failure question
I looked around and I could t find a solid answer..Ok so my CEL was out, I opened up the cluster to find my CEL was bridged to another non working light. So I removed the wire, turned the key over and the CEl came on.. should have left it alone BUT!! I'm dumb, so wanted to know why that bridge. So I bridged it back to the nearest working light. I cranked it, and my RPM, MPH, TEMP, and FUEL gauges went dead.
The only things that work are my blinkers and my clock..... also my entire cluster lights are out.
I checked all the fuses, they looked good.
My question is, based on what I have told y'all, and the fact that all the fuses were good, and it was working beautifully before. Is it safe to say I need to replace my cluster???
