![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Built s13 SR Partout
Built s13 SR part out
Everything has 7k miles on them Everything is OBO Will trade for 1jz parts Shipping up to the buyer. Tomei Ras 40 CP .020 9:1 pistons Has some wear, ring lands and skirts look ok. SOLD Eagle Rods SOLD S13 steel 1p DSS DS SOLD CS pulley set Sold Exedy stage2 clutch and PP, It slipped on the dyno at 363hp 344tq 125 Ka trans w/sr BH 150 SR flywheel w/fw bolts 55 Nismo fpr SOLD JWT ECU needs retune SOLD Turbo water and oil lines 60 SR head (stock) with stock cams SOLD ARP head studs SOLD Intake Manifold with IACV 45 Throtle Body/wauto tps 40 Throtle Body/w5-speed tps 40 SR20det Water Pump 20 Crank Angle Sensor 40 Coil Packs with harness SOLD HKS turbo timer 35 Oil coller setup 250 Earls 16 row oil cooler -10 ears line with 90 swivel fittings CS sandwich block SR Alt 60 7M Fidanza lightweight FW BN $220 Pics up in a few Last edited by di-devol; 02-25-2013 at 08:34 PM.. |
^No, the crank seems to have a gouge in it near the crank pulley. The front main will not seal because of this. This is the reason to part out, It would have to be taken apart and have the crank replaced/repaired. I could sell the short block, but it would include the cp pistons and eagle rods. Which would be more than 300.
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 19 reviews
Interested in the Pistons and the Rods. Is there any kind of scorching, pits or scratches in them? And is the .020 the oversizing so are they a 86.5 bore?
Also is there anything wrong with the rods like over heating or spun bearing?
![]() Team Prettyboys |
The turbo lines are custom, comes with fittings. oil feed is a -3an swivels* comes with an adapter for the block. Water line is a braided line with swivel an fittings. I'll get pics of them for you.
The rods are in perfect condition, no spun bearings. The pistons have some pitting on the top dish part, the ringlands are clean, I'd still run them. But if interested in both the pistons and rods, I'll give you a deal for the set. |
#17 |
![]() Join Date: Jul 2006
Trader Rating: (53)
No rings with those pistons? - send me more detailed pix please - [email protected]
#19 | |
#21 |
Ok great. What kind of deal can you give me for the set? Also those apr head studs is there anything wrong with them like being out if round, bent or anything like that?
#27 |
How much for the oil cooler and lines?
