Old 09-17-2009, 08:46 PM   #1
Charsiu
Charsiu is an unknown quantity at this point
KA24DE with T25 and sidemount setup? Questions :D
Hey guys, I am about to boost my stock KA24DE now and was thinking to setup my own kit instead of buying the ebay full kit for cheap.
I want it to look stealth and stock, so I was thinking to use SMIC
Here is the list so far I want to get after a few searches.
-T25 turbo from SR's
-T25 uppipe and o2 housing
-Turbo manifold (bottom mount) for KA24DE
-stock SR's SMIC
-CX racing SMIC piping for SR20DET
-Intake that fit SR20DET
-oil and water lines
-downpipe
Here are my questions
Do I need a Boost Controller?
I am planning to run only about 5psi ~ 7psi, can I use my stock exhaust?
Are the item I listed above able to fit into my KA24DE?
Did I miss anything else that was needed for a KA24DET build?
Thank you very much!
Charsiu is offline   Reply With Quote
Old 09-17-2009, 08:59 PM   #2
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
Why not just use stock side mount piping??? Is it suppose to be aluminum??? If so, i would say the stock piping looks more stealth.
bl3ujay07 is offline   Reply With Quote
Old 09-17-2009, 09:00 PM   #3
Charsiu
if they will fit fine, then I guess I will use the stock piping
But I am not sure if the SR stock piping will fit KA, do you think I can do that?
Old 09-17-2009, 09:15 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
NemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfection
Send a message via AIM to NemeGuero
most of it will work. I think you have to trim the TB section or get a coupler.
Search for S14UNIMOG's thread on his Ka-t. He did that shit and did it LEGIT.
You don't need a boost controller if the spring inside your wastegate is the right boost you want. They come in different pressures.
5-7 psi might start choking a bit on a 2.25" exhaust.. I'd upgrade to at least 2.5"
And you missed the biggest part.. tuning and ignition control. DONT CHEAP OUT ON THIS! for simplicity get an Enthalpy ECU or Nistune/CALUM. Do some research to decide which is better for you.
NemeGuero is offline   Reply With Quote
Old 09-17-2009, 09:18 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
Oh, and your list doesn't even have a wastegate or blow off valve.. though I'd argue you don't need a BOV for the setup you have listed.
Old 09-17-2009, 09:33 PM   #6
jholman05
jholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nice
Send a message via AIM to jholman05
Here's my old setup, the engine bay looks cleaner than that now but whatever.
www.ka-t.org :: View topic - Jholman05 232hp/240tq t25 Inside
I know my setup isn't perfect but it's lasted a year and a half now, I put a gti-r t28 on it earlier this year and everything is still good to go, just need to put the 550's in, hook the meth up then turn the boost up and get it tuned.
jholman05 is offline   Reply With Quote
Old 09-17-2009, 09:45 PM   #7
Charsiu
Thank you very much for your help
Actually, can I use the stock BOV on the stock SR's SMIC? and the stock wastegate from the T25?
once again Thanks!
Old 09-17-2009, 09:48 PM   #8
Charsiu
Thanks a lot! that look really clean!
Old 09-17-2009, 09:57 PM   #9
!Zar!
!Zar!'s Avatar
once again Thanks!
Yes .
Old 09-17-2009, 09:59 PM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
Oh mel, never more words than required. OMG its not 12 characters? haha
Sup dude?
Old 09-17-2009, 10:06 PM   #11
!Zar!
!Zar!'s Avatar
OP: Uhh, you need engine management. As well as injectors. WHY HASN'T ANYONE MENTIONED THIS?!
Sup dude?
Sup Evypoo. Are you still down there or what? We need to go out for a drink. Haven't seen you since last summer.
Old 09-17-2009, 10:18 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
I did mention management..
injectors.. ehh its 5 psi.
I'm in freaking Texas dude.. it sucks out here.
Old 09-18-2009, 09:01 AM   #13
jholman05
Just get an n60 mafs for like $30 from a pull and pay, get some 370cc injectors for $100 shipped, then get a calum ecu for $350ish and you'll be set, use the stock sr bov, get a cold air intake cut it like mine, cut the cold pipe on the smic and mate them. This setup is super easy. Also all you'll need to do is get the 370cc stock fuel pressure, n60 .bin from calum and you'll be up and running in no time. Also might want to move to a colder plug, I think i have bkr7e's or something like that.
Old 09-18-2009, 09:29 AM   #14
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
member of this board UNISA_JECS did this. look him up.
clark is offline   Reply With Quote
Old 09-18-2009, 11:53 AM   #15
NemeGuero
No more nissan.
NemeGuero's Avatar
wasn't that the dude selling the "how-to-KA-T" videos?
f-that..
zilvia's got the info for free and I already told him to look up S14Unimog's thread..
that doesn't cost money
Old 09-18-2009, 12:29 PM   #16
240cracker
240cracker's Avatar
240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute240cracker has a reputation beyond repute
Send a message via AIM to 240cracker
im doing the same thing pretty much...
but with injectors n60 maf and a chipped ecu.
if u want it to last id rsay do the same.
i have 390cc injectors forsale btw
240cracker is offline   Reply With Quote
Old 09-18-2009, 12:50 PM   #17
clark
clark's Avatar
f-that..
lol i didn't now he did that, he seems like a pretty straight shooter and knows alot about nissans. i was primarily telling him to look up threads that he made. i remember he had a thread showing pictures and stuff. it was a really clean stock looking ka-t.
here it is, i found what i was referring to:
#/f/chat/180650-my-k...-finsihed.html
and more pics here
#/f/tech-talk/176575...e-ka24det.html
Old 09-18-2009, 05:17 PM   #18
NemeGuero
No more nissan.
NemeGuero's Avatar
I could be thinking of the wrong dude. Its been a while.
Old 09-18-2009, 07:11 PM   #19
redpotatoes
redpotatoes's Avatar
redpotatoes is on a distinguished road
If you are interested, I have a GT2560R for sale (T28, JDM S14 Turbo's).
N60 and 370cc will be perfect if you are not planning to boost past 10 psi. I suggest at least a 2.5" exhaust system. You don't need to have a boost controller if you don't want to boost past the factory wastegate (which is ~7psi on a T25). If you have questions, I will be glad to help you out.
redpotatoes is offline   Reply With Quote
Old 09-18-2009, 09:39 PM   #20
NemeGuero
No more nissan.
NemeGuero's Avatar
Don't listen to the canadian!
haha
just kidding
Old 09-19-2009, 07:52 AM   #21
redpotatoes
haha
just kidding
You always have something nice to say lol
Old 09-19-2009, 09:35 AM   #22
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
You don't have to get an N60 MAFS. I used the stock S14 KA MAFS and it won't max out until almost 10psi. Honesly, I would recommend Nistune before any reflash, its inevitable that your setup will change/grow so why not have full access to your ECU. I used a stock BOV from an Evo VIII on my set up with the S13 SR side mount. Here's the thread Neme was talking about; btw, thanks for the props!
#/f/tech-talk/95722-...-pictures.html
My thread actually got bumped, here's a picture of mine
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 09-19-2009, 09:40 AM   #23
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
why is everyone helping this guy this as been covered a million times before send him to ka-t.org and be done with it
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 09-19-2009, 09:56 AM   #24
mattro
mattro's Avatar
mattro is an unknown quantity at this point
hey ive got some stock det parts you can have if you pay shipping. pm me what you need and ill see if i have it, good luck with the build.
grip like roots, float like leaves.
wtb s13 sus.
mattro is offline   Reply With Quote
Old 09-19-2009, 11:34 AM   #25
redpotatoes
Originally Posted by s14unimog View Post
... its inevitable that your setup will change/grow ...
That's why a N60 would be a good thing to have.
Old 09-19-2009, 12:07 PM   #26
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
UNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond repute
Feedback Score: 40 reviews
Send a message via AIM to UNISA JECS
Heres my setup and its gets 400+ miles per tank on the highway, Nistune, wideband and map sensor baby!
UNISA JECS is offline   Reply With Quote
Old 09-19-2009, 12:15 PM   #27
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Very nice setup bro. If I ever consider boosting the KA I'm going to hit you up for some pointers.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 09-19-2009, 12:24 PM   #28
s14unimog
s14unimog's Avatar
That's hot, A+ job on that one.
Old 09-19-2009, 05:20 PM   #29
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
I was reading the your thread on that set-up, did you ever have it dynoed?
SPENCER DOUGHERTY RIP ME OFF. SEARCH HIS REVIEW THREAD.
jonnybonds84 is offline   Reply With Quote
Old 09-19-2009, 06:17 PM   #30
dallaceseiuli
dallaceseiuli's Avatar
dallaceseiuli is an unknown quantity at this point
i love u ^^ now come help me.
you ed hardy wearing f150driving mexican immigrant !!
dallaceseiuli is offline   Reply With Quote
