Cusco zero 2 preload questions
Hi!
I bought a used zero 2 set recently, but don't have any instructions. Car is an S14. I have two questions about setting preload: - How much should I run? (was thinking between 0-2mm) - How should I set preload accurately on the rear with the helper springs on? (wanted to remove helpers, but the thread was ended before I could even set it to zero) Any help, ideas welcome! Thanks in advance! |
