![]() Join Date: Sep 2008
??Running with 7 out of 8 t-manifold studs.???
I fucked up. Got home from work and I wasnt too tired so i decided to work on the car. I was finishing up tightening the manifold nuts and on the last one I went to tight and cross threaded the head. The whole stud came out with some metal shavings. So I know the head is cross threaded, it won't thread back in. its the bottom right hand corner stud (s14 sr)
Upon researching I see that tap to a bigger size and helicoil it is the best solution. But the engine is I the car and I really dont have the time or cash to do so or take it to a shop. What if I run with all but that one stud? |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
shouldnt be a "major" problem, ive done it a few times...
also you dont have to pull the motor, just take off the manifold/turbo and you should have the space to drill n tap.
