Starter issue after relocating fusebox
Ok, it has to be simple as i ladeled every wire twice and did each wire at a time. I'm thinking the starter harness got crossed maybe by repinning a connector from the fusebox that runs to it.
The issue is when i go to start the car, the car starts cranking on the second click turn(start positon) on the igintion without having to turn the key over also after the car starts it sounds like the starter is still spinning and not shutting off after the car is cranked.
I have the fsm out and the b/w wire is going where it should any thoughts?
