i have already tried searching for this but was not succesful. i jsut got my JDM 180SX kouki tail lights in and there is only 3 pieces( the two lights and the center piece). from what i have heard and seen there is suppose to be the metal piece under the lights too. my question now is, can i use the existing peice that is already on my car or am i SOL, please help! thanks in advance for any help and suggestions!
![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
nope, you can't use your stock piece.
you got screwed.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till. -Emerson |
![]() Join Date: Aug 2002
i think some places can order it for you. here are some parts numbers you might need:
Bottom Piece: 26540-60F05 Lock and Key: 90600-60F25 if not, you can use your stock piece. you have to cut it but it should fit. i tihnk the zenki/chuki bottom piece is larger so a hack job would work. i had a friend who picked up just the center piece and tail lights like you for about 200 and he hacked his stock bottom piece to work. |
#6 | |
