![]() Join Date: Jul 2007
Trader Rating: (106)
SHOP CLEANOUT! Brembo calipers, TONS of smalls, aftermarket and OE, CHEAP!!!
Well, it's time to clean-out the shelves here at the shop! I have finally gathered all the random parts sitting around that I think someone else might need. I will ship, unless stated otherwise. I will make package deals and will be much more willing to lower the price for pick-up/cash transactions. Remember, shipping is a PITA and my time is valuable...
Parts are located at my work in Northridge, 91324... Work RS-Beta centercaps These are 3 ORIGINAL Work RS-Beta centercaps. Two of the caps are in pretty good shape, just some small scratches in he clearcoat. The thirdcap has the clearcoat peeling and would need restoration to look good. $20/ea for the clean pair $10 for the damaged one S13 subframe bushing inserts This is a BNIB set of S13 subframe bushing inserts, made by energy suspension. These slide into the hollow areas of your stock bushings to stiffen them up a little. EVERYTHING is included, bag is unopened. $10 S13/S14 rear knuckle/arm bushings This is a loose pair of brand new bushings for the rear knuckles or the rear suspension arms on an S13 or S14. These will NOT FIT S14 stock toe arms as those bushings are wider. I ONLY have the pair of bushings. This would be great for someone running stock trac arms with adjustable rear toe/camber arms. $10 S14 passenger's side urethane steering rack bushing This is a passenger's side steering rack bushing for an S14 chasis. It is made by energy suspension and has never been used. $5 KA M/T starter bolts This is a mis-matched pair of bolts for the KA w/manual transmission starter bolts. Both bolts are metric grade 8.8 and both come with lockwashers. The heads of both bolts are also the same size so you can use the same socket. $10 shipped S13/14 clutch and brake pedal pins These are the pins for either the clutch or the brake pedals on an S13 or S14. These two are actually from the brake pedal, but will work on either one perfectly. I have 5 of these available! ONE is an actual clutch pin, not that it matters... $5/ea S13 clutchline bracket This is the bracket for the clutch line on an S13. These are commonly left out on swapped cars. $5 Sidemount Seat Brackets This is a pair of sidemount seat brackets. I have no idea what seat these are for. The seat must be much narrower in the rear than the front. $20 Pair of Spacers for TEIN tension rods This is a pair of spacers for TEIN tension rods. If you lose these you're screwed so I figure someone could use them. $20 Redtop SR coolant sensor subharness This is a coolant sensor subharness for an S13 SR20DET. The harness is in good shape, no issues. $15 Pigtails/connectors for SR wiring I have two complete sets of connectors for wiring an SR harness for a 240sx chasis. The connectors are all in good shape, no issues. This would be perfect for someone who doesn't want to hack-up their KA harness or if you don't have the stock engine harness. For the underdash plug I DO NOT cut and solder the wires. I simply re-pin the wiring into the new connector. For a dualcam swap you just swap the pins directly across to the same position in the new connector. For the SR wiring you'll have to do a little more research on how to pin them. FR sport has a GREAT write-up. Two of the underdash plugs are already de-pinned and one of the others isn't actually for the underdash harness so the wire colors won't match. I also have the dash harness connector separately for those of you doing a DOHC swap. $15/set (specify if your chasis was originally SOHC or DOHC...) S14 KA IACV This is a good working S14 IACV valve. It's in good shape no damage. I'm not sure if it would work on an S13 KA, you would need to check the part numbers to be sure. $20 S14 KA EGR solenoid This is a good condition used EGR solenoid for an S14 KA24DE. New these are about $100 from the dealer... $20 KADE or SR oil caps This is a pair of oil filler caps for an SR or KADE. These will NOT fit a singlecam and I don't know about CA. Both caps are in good condition. $5/ea all black cap on left SOLD!!! KA dipsticks These are both KA dipsticks, one singlecam one dualcam. Both are in good shape, no damage. The dualcam is on top in the pic and the singlecam is the longer one on the bottom. $5/ea S13 SOHC injectors This is a set of 4 S13 SOHC KA injectors. ALL injectors have been tested electrically, terminals cleaned, and are known to be good. NO seals are included. Nissan injectors LOVE to take a shit, everyone should have a spare. $10/ea CLEAN S13 cluster bezel This is a SUPER CLEAN S13 guage cluster bezel. No fading, very little scratching, no cracks. The only issue is the little rubber skirt that goes along the back is missing. $15 S13 driver's and passenger's side dash vents These are a pair of S13 dash vents, passenger's side and driver's. I do not have the center vent. The vents are in pretty good shape, 100% functional. $5/ea S13 fastback headliner This is a headliner from an S13 fastback. The headliner is in pertty good shape, no rips or burns just needs cleaning. $15 S13 passenger's side window switch/handle This is a good condition passenger's side inner door handle with the power window switch for the passenger's side of an S13. The handle is in very good shape, just the writing is worn off like normal. $15 S13 dash switches These are random S13 dash switches. All are in good working order and would just need a little cleaning to look nice. I have 2 complete sets available (pop-up, flasher, rear def, and dimmer). $5/ea $15/set of 4 one wiper switch SOLD!!! S13 push-button delete panel This is a good condition push-button delete panel for where the rear wiper switch or factory foglight switch would go on an S13. The panel is in good shape, just some very light scratches here and there. The clips are also included, just push it right in! $5 S13 inner door handle screw covers This is a pair of the screw covers that go in the bottom of the inner door handles on an S13. These are usually missing and are hard to find. Will post better pic, I didn't realize how out of focus that was... $10 shipped S13 manual window crank These are window crank assemblies for an S13. They are faded as usual, but compared to a lot of them is in pretty good shape. The clip and the plastic washer are included as well. I have 3 of these available, only 2 are pictured... $5/ea S13 "oh shit" handle This is the handle for the passenger's door on an S13, commonly referred to as the "oh shit handle". I have 2, both are very clean. $5/ea S13 cluster subharnesses This is a pair of instrument cluster subharnesses for an S13 chasis. The harnesses are in good shape, no damage. $10/ea S13 pop-up headlight subharnesses These are 3 S13 pop-up headlight subharnesses. These are often damaged or missing. Most people don't know that Silvia headlights SHOULD come with a subharness of their own that plugs into this harness for the headlights. $10/ea COMPLETE 91-94 engine bay body harness This is a COMPLETE UN-CUT engine bay body harness for a 91-94 240sx. It originally came from a coupe, but is the same on a fastback as well. The car this came from was full-options so it will be compatible with whatever power options you may or may not have. $50 S13 rear hood seal This is the seal that goes along the back of the engine bay and seals the hood for an s13. The seal is in good shape and all clips are included. $5 S13 corner lights These are good condition S13 corner lamps. The rears are a matched set, left and right, and come with the sockets. The fronts are BOTH for the right side and ONLY ONE comes with the socket. You can use them on the left side as well, the writing on the lens would just be upside-down. $5/ea Stock fastback rear tail light panels These are the stock USDM tail light panels for an S13 fastback. Both panels are straight, no bends or dents. $10/ea S13 fastback rear bumper This is a stock rear bumper from an S13 fastback. The bumper is in pretty good shape, just a small scuff on one corner and some paint damage on the other. $20 S13 front swaybar link This is a front swaybar link for an S13 chasis. It should work on an S14 as well. This one is in good condition, moves free, nice and tight. $5 RANDOM CRAP... I also have a whole shitload of small random stuff as well. I've got 3 boxes full of wiring, relays, switches, and other misc electrical shit. I've got 2 parts shells, one coupe and one hatch. If you need a random small part that's not listed HIT ME UP! I probably have it... Random wiring: Misc. Electrical: The infamous "240 bucket": Coupe parts shell: The HUD windshield is spoken for on this one, sorry. Was a full power option car, pretty well parted out though... Fastback parts shell: The windshield and tires are spoken for on this one, sorry. This car was manual everything, no power, and is also pretty well parted... Last edited by racepar1; 10-19-2013 at 03:02 PM.. |
![]() Join Date: May 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
i need alt fuse located in the electrical box nearest battery, the fuse itself in located in the corner of THAT box, 75a i think and i have a 1990 ka24E text me 562.522.9340
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
really weird request...but im needing a good, non broken part off the gas door lock. the actual piece inside the car where the cable splits to either pop trunk or gas door.. there is an x looking bracket. i want that whole assembly. with all parts that attach to it. also -- very interested in picking up that power mirror delete cover.. lemme know if you have that gas door catch piece thats not broke.
![]() Join Date: Feb 2011
on the coupe how much would it be to ship the roof to florida. I need the roof cut off at the bottom of the pillars. pm me a quote on a shipped price if you could thanks
#12 | ||
I'm not sure how to get a quote on shipping that, but I'll try. I'll Pm you with what I find. |
