Large selection of 240SX Parts that need to be gone!! - Free Ship on certain items
: Ro
: Loudoun County, VA : Post/PM for faster response : NO Trades : Paypal+3% or CASH : Free Shipping on certain items or local pickup EVERYTHING IS OBO MOST parts are taken from a '95 Zenki Emerald Door Panels(Passenger and Driver) - 8/10 condition $25 each - PENDING S14 Brake Master Cylinder w/Booster - Works fine, No problems, No leaks $60 Seats w/Rails - 9/10 condition.some cig burn marks $120both Shift Boot - torn up a bit SOLD Nismo Shift knob(threads on fine) $70 Sunroof control/Map light FREE Gas Tank - No leaks $80 Z32(300zx) MAF pigtail - Brand New $30 ![]() Stock S13 Redtop SR20DET Fuel Injectors - Purple $65 - all four ![]() 350Z OEM Tinted Reflectors - Brand New $50 S13 Redtop Valve Cover - No Cracks $55 Setrab Oil Cooler $60 ![]() ![]() S13 240SX OEM Hatch Rear Tail Lights and Garnish $60 RB20 Down Pipe(Left) and S13SR Down Pipe(Right) $40 each Radio Trim - w/slight crack, broken tab(still mounts fine)and missing cig. plug (Does NOT come with guage setup) $60 -- Radio trim and guage setup - $95 A/C Trim - No damage, except the drill holes between vents (Does NOT come with guage setup) $45 -- A/C trim, 2 guages, and boost control setup - $230 Auto Meter Sport Comp #3303 Boost/Vacuum, 30 in. Hg./30 psi Mechanical, 52mm - Needs plastic tubing $30 Auto Meter Sport Comp #3344 Pyrometer, 0-1,600 Degrees F Electrical, 52mm - Comes with everything needed; Type K thermocouple and wiring harness $100 Auto Meter Sport Comp #3327 Oil Pressure, 0-100 psi. Electrical, 52mm - Needs 1/8in. NPT sender and 1/4 in. NPT adapter/fitting. $40 TurboSmart Boost Controller In-Cabin adjust w/ T-fitting $80 -- Whole Setup(A/C trim setup + Radio trim setup) - $320 4 - Yokohama Advan S.4.'s 245/45/19 - 10/32nd's left on all 4 - Tires were used for 500miles $525 Last edited by roorr0; 11-10-2009 at 03:23 PM.. |
shipping for seats will be extra. will let you know if im willing to ship. which seat you looking to get?? |
#16 | |
460
