Old 08-22-2008, 06:19 PM   #1
cbates14
cbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond repute
Send a message via AIM to cbates14
Question coolant/water flow through turbo - need confirmation
so i just installed the gt3071r, and after doing some research i need to confirm that it doesn't matter which way coolant flows thought the center cartridge. meaning, either port could be used as an inlet, or outlet for the coolant.
just want to triple check it, before i really get on it
cbates14 is offline   Reply With Quote
Old 08-22-2008, 06:25 PM   #2
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Nope it dosen't matter at all I ve had mine both ways and it's never made a differecnce. If you had an oil cooler you dont even need to run water lines. IMO
WoolyS14DET is offline   Reply With Quote
Old 08-22-2008, 06:42 PM   #3
cbates14
sounds good, thanks!
also,
is it normal for the turbo to making a distinct sound at idle? hard to describe, but its almost sounds like a constant ringing... am i just paranoid?
all the lines are properly hooked up - oil, and now confirmed, water.
Old 08-22-2008, 08:34 PM   #4
Sileighty_85
Sileighty_85's Avatar
Originally Posted by cbates14 View Post
is it normal for the turbo to making a distinct sounds at idle? hard to describe, but its almost sounds like a constant ringing... am i just paranoid?
It will (sounds like diesel) if your not running an exhaust, or if your running a straight through exhaust
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-22-2008, 08:44 PM   #5
Def
The compressor at idle will sound kind of like a ringing sound. Rev it up and it'll change pitch as it spools.
Old 08-22-2008, 09:23 PM   #6
cbates14
ok, as long as the ringing is normal. just dont wanna f up a brand new turbo before enjoying it
thanks again!
