![]() Join Date: Jun 2007
All prices are shipped within the continental U.S.! No waiting for shipping quotes, and typically I can ship anything next day through my work. PM me or for the quickest response text me at 513-869-0556 any time
RB25/26 starters - $40 - used - known good OEM Nissan unit (Top is available, bottom one pictured is sold) ![]() RB26 Alternator tensioner bracket - $20 ![]() RB26 Valve spring compressor - $120 - New - I make these, it's the only one of its kind as far as I know and works extremely well. Bolts to the cam cap holes and allows you to disassemble valve springs either on a bench or on an assembled engine with a pressurized cylinder. All steel construction ![]() RB26 cam sensor brackets x2- $20 each ![]() RB oil caps - $15 - used - One OEM, one Ebay style RB26 rear water port fitting - $15 - used RB26 turbo return line fitting - $15 - used - part that threads into the block for the front turbo oil drain ![]() Universal 6an fuel/power steering cooler - $20 ![]() RB26 coil packs (individual) - $15 each - used - missing stalks but good otherwise ![]() RB26 coil pack set with harness - $50 - used - known good set, includes good sub harness and bracket ![]() RB26 balance tube - $20 - used RB26 oil filter housing - $25 - used ![]() RB26 seal driver set - $40 - new - Seal drivers for the front main, rear main, and cam seals. Very solid 3d printed construction, holds the center spring in place and allows you to tap the seals in with a hammer without worrying about damaging them. RB26 water necks - $15 each - used - bottom one has an additional port added, top now has the small outlet welded shut for single turbo use ![]() RB OEM water pump pulley - $15 - used ![]()
RB26 S14 Kouki
| gtr, rb20, rb25, rb26, skyline |
