![]() Join Date: May 2012
240sx s13 hatch driveshaft
I have an s13 hatch I've converted to 5speed and I bought a drive shaft from a local guy and the carrier bearing is on the second half when I need the bearing to be on the first shaft its non abs non LSD is there a way I can swap the first piece with someone or what?/
