need help transmission isnt coming out!! plz help!
i have an rb25 im am trying to remove the tranny to replace the clutch i have all the bolts taken out of the tranny, but when i go to try and take it out it seems like it kinda springs back into place and wont come out i dont know if there is a trick that i dont know or what i never taken one out if you guys could help me that would be great thanks in advance any help is much appreciated!!
![]() Join Date: Dec 2004
Trader Rating: (58)
Got all the bolts out?
Before removing the slave cylinder, push on the cluch pedal...sometimes this helps push stubborn transmissions back a bit back.
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() Feedback Score: 9 reviews
what car is this in? odds are your hitting the firewall...
TW: #/f/cars-sale/390459...d9s-coils.html |
Starter removed all the way?
Slave disconnected? disconnected clips for sensors? I had to rotate my transmission to allow me to pull it off. The starter bump in the bellhousing wouldn't clear the tunnel. Rotate = solved. |
does the starter have to be removed? its a r33 skyline and its not hitting anything.
When we pulled the motor in my freind r33(we did 5 of them) we dropped the whole front subframe and motor lol... but it was a pita... everything is disconnected right, drive shaft, tranny mount, all the bolts, i would take the starter off to i think the bolts that hold it on are also used to bolt the trans/motor together, clutch slave/lines, i you may have to tilt the motor back a little to get the trans to come out...
