![]() Join Date: Feb 2002
*NOW IN STOCK*
____________________________________________ Engine Application: Nissan SR20DET - S13, S14, S15 and RPS13 Rear Wheel Drive (only!) Manufactured from aircraft aluminum Dual internal baffling insures oil control not present in an OE oil Pan Bolt-in upgrade replaces OEM steel pan Use Stock Oil Pump & Pickup ¼" aluminum rail Metric studs and nuts included Oil Temperature provision Magnetic drain plug included ____________________________________________ Click here to order ===> http://www.enjukuracing.com/products...n-sr20det.html
Yeah, these are really nice especially if you're on a budget but still want a great, quality made pan. This should be the same style pan Moroso has been selling for the SR for quite some time now.
