have anyone installed a 350z diff on a s14
Hi guys i am in the process of installing my v160 on the s14 and the only diff thats close enough is the 350z auto diff (3.35) . have anyone have done the swap before? also whats the spline count on the outputs shafts ? 31 like the q45's . Thanks in advance......Omar
618 whp tuned by alpha |
I think Stew has Omar. His name is Johny5 on here. He has experimented in a few setups and the last time I spoke with him he mentioned something about the Z33 rear. Is the Q45 not cutting it? Let me know because I am on the same route as you bro.
Thanks for the info, i look onto it. If you are on a r154 either q45 (3.54) or (3.69) depending on your tire height (26" or 28") work perfect but if you going v160 you need something taller than a 3.54 , i am guessing my best bet is the 350 vlsd auto 3.35 . I want to hit the traps i fourth gear with out reving the car to the sky .
618 whp tuned by alpha Last edited by babillaracing; 03-21-2012 at 06:59 AM.. |
Yes, look for Stew on here. I believe there was a recent post about this. I know his website has a run through of what is needed.
My SR20VET |
Here's the link Omar... I'll PM you with it on TR as well.
350z Differential and Axle Upgrade with OS Giken LSD - Stewart Leask
My SR20VET |
